BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Fault codes of F20 118i
      03-29-2018, 03:42 AM   #1
galbo
galbo's Avatar
Drives: F20 118i
Hello everyone,
very nice place here
i have 2012 n13b16 engine and had the drivetrain message on the idrive screen. when it happened car went to low power state (limp mode?) and also was shaky at idle.
When i went to official BMW shop the first told me i need to replace the cylinder head cover. according to them there is some kind of valve inside it which was stuck. they replaced it hoping the errors will go away but no luck.
i have attached a screenshot of the errors shown at the shop.
eventually they told me my DME is bad and needs to be replaced.
somehow i do not trust them (i deem they are not professional). i have the feeling they dont really know the cause and just guessing.
has anyone had the same errors? or symptoms?
thank you all
      03-30-2018, 02:35 AM   #2
Sidewinder1970
Sidewinder1970's Avatar
Netherlands
13
Drives: BMW f20 116i
2012 BMW F20  [10.00]
I experience the same message, exept voor de limb mode. Rubber of the electronice valve on the turbo was torn. Replace it with a GFB DV+ and everything was good.
The engine cover do have a vacuum reservoir with 2 small rubber hoses. If you take the cover off and forget to refit those small hoses you can get the same message. Read somewhere that a faulty camshaft sensor could make those messages to.
Good luck man!
      03-30-2018, 03:35 AM   #3
galbo
galbo's Avatar
Drives: F20 118i
thanks for the reply.
i think i will ask them about the hoses inside the cylinder head cover.
does it sound reasonable the DME gone bad?
      03-30-2018, 03:52 AM   #4
BimmeRCK
Drives: 1 Series F21
I have experienced the same about 2 years ago, with the same messages. In my case both the intake and exhaust electromagnetic valve of the camshaft (Vanos) had to be replaced to resolve it. 2 different instances about 5 months apart, one of them was within warranty period luckily.
Not a cheap fix unfortunately, but never had the message since, so good to have those checked.
Good luck!
      03-30-2018, 09:19 AM   #5
galbo
galbo's Avatar
Drives: F20 118i
thank you.
to be sure, you had the drivetrain error or the fault codes like in the picture?
      03-30-2018, 10:01 AM   #6
BimmeRCK
Hi galbo,
I had both actually , so could be the exact same issue. If it is just 1 of the electromagnetic valves I would recommend having both changed, since 5 months after changing the exhaust one, the intake one failed on mine.
      03-30-2018, 12:03 PM   #7
DomMuc
DomMuc's Avatar
501
Drives: G87 M2
your problem is the missing Clamp 15N_2.. check the wiring diagram i think all those Sensors are supported from clamp 15N_2 ..
      04-01-2018, 12:14 PM   #8
galbo
galbo's Avatar
Drives: F20 118i
thank you guys. i will check and update after since the car is at the shop right now.
DomMuc - can you please ellaborate on the 15N_2 clamp?
      06-16-2018, 02:02 PM   #9
TroyBE
TroyBE's Avatar
Belgium
Drives: BMW F32 435i
I had the same error, only my problem was resolved after changing the engine oil xD
2017 - 2020: BMW F20 114i 2013
2019 - now: BMW F32 435i 2015
      03-02-2023, 11:30 AM   #10
djoes16
Poland
Drives: BMW F30 2018, BMW f34 2016,
Hello, any update or solution for that? i have same problem with f20 n13 2012. I changed MAF, dme (used) and presure valve. I have still same error.
vanos have 7.7 ohm - in servis info 10.1 ohm
      03-04-2023, 01:27 PM   #11
FA49J
FA49J's Avatar
Singapore
Drives: M135I 2013 PLCI
2013 BMW M135i  [0.00]
  [0.00]
I had the same issue where the car looses power. Found out the charge pipe was loose.
