BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Supersprint exhaust for 120d
      08-08-2013, 03:25 AM   #1
GregSen
GregSen's Avatar
Belgium
11
Drives: 120d
So, after installing a M Performance rear part exhaust, i still miss something with my 120d... NOOOIIIISEEEE
I asked some infos to SuperSprint and they gave me an answer... so here it is:
You shouldn't have any issue with the warrany as you're not modifying parts like the DPF, sensors etc.
In terms of performance you won't get any increase as it's a diesel, for that you will need a ECU remap.
What you'll get is a much nicer sound and improved looks!
You may have seen our application on the website, and as you can see we have a number of solution.
http://www.supersprint.com/en/IT/pro...hp_2012__.aspx
What bumper is fitted to your car? With the normal and the M-Technick ones all the solution are compatible, while with the "performance" just the single exit on the left is ok.
My favourite configuration is the dual exit, one for each side, without the silencer.
It looks very good, especially with the M bumper, as it looks almost like the M135i. The bumper must be trimmed.
It also sound nice, with a sportier and deeper tone:
http://www.supersprint.com/en/doc-s-..._exhaust_.aspx
With the silencer it's quiet but still better than stock, and it's TUV approved:
http://www.supersprint.com/en/doc-s-...aust_oo80.aspx
What do you guys think about those possibilities?
I still can't decide anything, too scared to be disappointed...
Help plssss
      08-08-2013, 03:58 AM   #2
Bradbury
Vroooooom!
Bradbury's Avatar
Drives: F20 120d
I've been thinking about getting the one with one pipe on each side, although with the silencer. I just don't think my 4 cylinder diesel will sound better if it's louder...
It would look amazing though, and that alone might be worth the money.
      08-08-2013, 07:05 AM   #3
Dawko
Belgium
194
Drives: :
  [0.00]
Also been hesitating to get this one but 2 things are holding me back:
1. Is the sound really goong to be this better or noticeable?
2. If I'd buy it I'd go for the 'performance' instead of the silencer. But for that price?
You might look into Skytune since you're a fellow Belgian. They can make the same piping for probably less and I always wanted to put the dual M Performance with it for a more OEM look.
I don't mind spending any money on an exhaust for a 435i but for a diesel I'm not so convinced..
      08-13-2013, 01:25 PM   #4
vladberca
vladberca's Avatar
Romania
763
The stock one looks bad so you should take at least one model with 2 pipes, left side It's the 3rd model from what I've seen on their site .
