BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Cruise control retrofit help
      12-17-2021, 07:40 PM   #1
Westcoaster99
Westcoaster99's Avatar
13
Drives: 2014 330d msport
Hi, I recently fitted cruise control buttons on my f20 that previously just had a limiter. I've vo coded fembody bkombi and icm with 544 but when I used the button I'm still only able to get the limiter likes before. Does anyone have any ideas of what might be happening?
Cheers
      12-27-2021, 01:40 AM   #2
Maniver
Finland
Drives: F20lci 125i
I retrofitted cruise control to my F33 with these instructions (see pdf at first post). Should be the same with F2x
https://f30.bimmerpost.com/forums/sh...d.php?t=988282
      01-12-2022, 10:11 AM   #3
IREALITY
Drives: G30 and x6
Cheers
Cheers
Retrofit man
      03-09-2022, 01:55 PM   #4
clatu
Drives: F21
Hi , trying to change cruise control units from miles to km - F21 2013
have set metric units in idrive and milage now displays in km.
Cruise control still in miles .
Cluster is in miles.
Found this for same issue but no idea if it is correct for F21 .
Would you know ,thx.
In EHB module.....
SETZ_V_MAX_CC
wert_02 -> wert_01
SETZ_V_MIN
wert_02 -> wert_01
V_ABSCHALT
wert_02 -> wert_01
V_EINHEIT
wert_01 -> wert_00
