BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > M135i problem
      09-11-2019, 07:03 AM   #1
Slacky555
Drives: M135i
M135i problem
So I posted the other week thinking I may have a gearbox problem.
I have now had codes read and I have airflow low and high.
I have changed the MAF and not resolved. Plugs were done 5 months ago. No codes coming up regarding misfire so hopefully ruling out coils or plugs. It’s also a 2014 model so thought the issues with the hpfp had been sorted.
Problem is now getting worse.
One day basically went to put my foot down it kicked down but then no power.
I now have hunting revs intermittently at a stand still. On gear change at low speeds it jerks a little kinda bumps the revs up so you lurch forward. And absolutely has no top end grunt at all. It seems normalish when pulling out of a junction if you haven’t been stopped for long.
Any pointers would be great, mechanic mates had a look on the drive and doesn’t think there is a air leak what he can hear but it is booked in to check.
      10-05-2019, 02:43 PM   #2
maverick83
Drives: F20 M135i
Did you check the charge pipe...?
