BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > 2012 F20 Clutch
      08-02-2018, 11:12 AM   #1
JMC
Drives: BMW F20 118D Sport
2012 F20 Clutch
Afternoon all.
I own a manual 2012 118D Sport. I'm looking at getting the clutch replaced soon as it's starting to slip when flooring it in sport mode - but I'm a bit confused.
After entering my VIN, RealOEM says that the clutch with a 228mm diameter must be installed, and not the clutch with a 240mm diameter. I've had a look around and all parts stores (online at least) seem to only be selling a clutch with 240mm diameter, though the OEM part numbers listed do match what RealOEM has on their site.
So my question is, which is the correct clutch? The one with 228mm diameter, or 240mm diameter?
FYI, I'm based in the UK.
228mm, 240mm, clutch, f20
