BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > BMW 116i F21 N13 Remapped - Misfire Issues - PLEASE HELP!
      04-17-2020, 10:08 AM   #1
Teaspoonlizard
Drives: BMW F36 440i + F20 118d Sport
Looking for some help with my 116i F21.
I have had the car remapped now for maybe 3 years and have had multiple issues with misfiring. First time it happened, coil pack seemed to resolve the issue. The next, ECU repair. The next I send the ecu back for repair again, no issue so coil pack + spark plugs fixed it. The next, just a spark plug.
It's been about a year since the last problem and it's come back again, I tried replacing all plugs which hasn't resolved it. Now misfiring under load on cylinder 1. Should I try coils again?
Something that I noted when changing the spark plugs is they were ALL fouled. Looked like Carbon to me. The car was remapped at Superchips and I've asked them for their opinion on if the fuel mixture for the map is too rich but they assured me it's a closed loop system so that can't be the case.
A while back I thought it may be a leaky injector on cylinder three, but now all the spark plugs are black could all of the injectors be leaky?? Surely not, right?
Looking for some guidance here as I've run out of ideas. Can anyone offer some advice? Anyone have similar issues?
Thank you.
      04-23-2020, 04:04 PM   #2
raphaelpais
Portugal
Drives: F20 116i
2012 BMW 116i  [0.00]
have you checked the PCV valve? maybe it's cracked and you´re getting oil inside the cylinder..
      04-17-2022, 06:15 AM   #3
cosmi149
Drives: BMW F20 118i 2012
Hi, did you find any fix for it? I have the same issue on cylinder 4.
      05-02-2022, 02:26 AM   #4
IJO
Drives: BMW 116I F20
I had a misfire of cyl 4 after i had fitted new plugs last week.
It was nothing more than me not refitting the coil pack plug on properly.
When I bought the car last month, (116i 2014) the tailipipe looked like a last century diesel's.
It was the maf sensor causing overfuelling. It was 8years old and had done 85000 miles.
Superchips comment that the AFR is closed loop is only partly true. It is open loop during warm up, and when using large throttle openings so overfuelling, very sooty exhaust and plugs does happen.
