01-21-2019, 12:44 PM | #1 |
Rep 8
BMW 114d BUSINESS daytime running lights
Dear all
First of all hello I am new here and new to BMW. Searched the forum, but did not find answer. So posting thread. I own a white BMW 114d BUSINESS. A few days ago a warning message popped up, that I had a parking light failure. So I wanted to check a bulb. As far as know, to get to that small (H6W) bulb one needs to remove daytime running light bulb and then get inside with a long nose pliers. So I did that, found that bulb was OK, and put it back. Now bot side parking lights are O, but have warning message side/daytime running lights fault. I bought this car three weeks ago and I even did not look in the beginning were those daytime running lights on or not, since there were no warning or error messages. Now, when I am looking front of vehicle those two bulbs are off. Could it be, that I blew the fuse? Is there a fuse for daytime running lights? If yes, where it is? Or ... I even have no idea what could be, since this is first BMW for me. Thanks for answers in advance |
01-21-2019, 02:56 PM | #2 |
Rep 3,290
I don't know the answer, but I would suggest giving some information about what lights your car have. Is it the facelifted LCI model? Does it have halogen lights? Xenon? Leds?
01-21-2019, 03:21 PM | #3 |
Rep 400
daylightdriving lightbulb is the upper inner bulb looks likw you checked the sidemarkerlights
https://drive.google.com/file/d/0B1a...1FpeE5pdw/view Page 139 is a pic you could see where it is located /no 1) to check the daytimerunning lights engine needs to run and lightswitch needs to set on 0 ( off) |
01-21-2019, 11:46 PM | #5 | ||
Rep 1,354
Hello.
To have daytime lights on you should, besides what DomMuc suggested, make sure they aren't disabled, either. Why would you? From your description of what you did you shouldn't have. The car was shut off when you inspected the bulb(s), I presume. Just from common sense/knowledge, everything electrical should be protected. Well, address the manual. There are two locations. "Plastic tweezers and details of the fuse assignment can be found with the fuses in the boot." (page 263) |
01-22-2019, 12:16 PM | #6 |
Rep 8
Thanks guys for response . I think I found the problem. But I newer thought, that those two bulbsare wired in series. Anyway. One of bulb is burned. Another is OK, and unfortunately, at first I checked the one, which is good. Since I have never seen, that in the car two bulbs on two different side are wired in series and both bulbs are off, I started thinking about fuse.
It strange, that BM wired those two bulbs like this. Or, may be board computer shuts other one too, when one is burned. |
01-22-2019, 01:44 PM | #8 |
Rep 8
01-22-2019, 02:27 PM | #9 |
Rep 1,354
You shared you had checked a parking light bulb, both the location and kind (H6W). DRL ones are different in both aspects. It's not too clear what lights you actually refer to. It might even seem, not too clear for yourself.
01-25-2019, 12:08 PM | #10 |
Rep 8
Do I need to describe all my actions? I will give you a hint. If bulb is lit, one does not need more checks, that what you see. Another hint - parking light bulb.
