03-30-2019, 06:25 AM | #1 |
Rep 4
Bmw iDrive Controller change
I have iDrive Controller like the one in the photo, is it possible to change to the big one? if yes how can i do it because i cannot find anywhere how, i appreciate the help, thanks.
04-01-2019, 01:37 AM | #2 | |
Rep 134
1. Check either your old controller is connected to KCAN1 or KCAN2 From factory, to differentiate it K-CAN wires are green and orange and K-CAN2 wires are yellow-red and yellow-brown. If your car has KCAN1, it should need another module to plug the controller. since my friend's car has KCAN2 from factory, so i didnt look the module. 2.Minimum build date (Zeitkriterium) of your car to be 07/13 3. The NBT needs to be flashed to at least 50.4 psdzdata. 4. Some coding in HU NBT HU_NBT/3000_HMI/ZBE_TOUCH_INTERACTIVE_MAP set to aktiv HU_NBT/3000_HMI/ZBE_TOUCH_SPELLER set to aktiv HU_NBT/3000_HMI/ZBE_TOUCH_BROWSER set to aktiv HU_NBT/3004_SYSTEM/EINSTELLUNGEN/ZBE_TOUCH set to aktiv Goodluck! hope this helps. T
Instagram: @tafikhulafaa & @88tuning.id
04-12-2019, 03:57 AM | #4 |
Rep 1,409
A cross-link.
Here's a simple solution, perhaps: https://f20.1addicts.com/forums/show....php?t=1603250. It should remove the interface (connection) restriction/complicacy as well as coding. The same buttons (no dead ones added). FWIW
