BMW 1-Series Forum (F20) 135i - 1Addicts.com > BIMMERPOST Universal Forums > General BMW News and Cars Discussion > I'm throwing a code but nothing is wrong...
      03-06-2009, 06:14 PM   #1
Z22Z
Z22Z's Avatar
Armenia
33
Drives: WRX
About a week ago my car threw a code saying left brake light malfunction. I turned the car off to go call my friend out to check it out and when I started the car again the code went away. The lights were working fine and I didn't get another code until today. I checked the lights out and they were working fine, there are no loose connections, and the code only went away after I parked for about twenty minutes only to be thrown again. What could cause this to happen and what are possible fixes?
      03-06-2009, 06:23 PM   #2
MShao825
Go Terps!
MShao825's Avatar
53
Drives: 2009 SSII/FR E92 M3
There are 2 bulbs in each brake light, so 4 total (2 on the driver's side, 2 on the passenger's side). It's possible that one of the 2 bulbs on the left brake light is dying/dead, but you just didn't notice it when you looked because the other one was still properly lit. See if that's the case, because I had the same experience.
      03-06-2009, 06:26 PM   #3
Kensta335
Kensta335's Avatar
161
Drives: 335i Coupe
I had the same issue before. Take it to the dealership and they can resolve it for you.
      03-06-2009, 06:35 PM   #4
Z22Z
Z22Z's Avatar
Armenia
33
Drives: WRX
I forgot to mention that the left tail light was changed by the dealer because it had a problem shorting.
      03-06-2009, 06:36 PM   #5
Z22Z
Z22Z's Avatar
Armenia
33
Drives: WRX
wouldn't one light be brighter than the other?
      03-06-2009, 06:42 PM   #6
nnnnnnnnnnnnnnnnnnnnnn
Drives: 1
06 and 07 models have a poorly designed light housing unit. The bulbs aren't very secure. Go to the dealership and ask about the upgrade on the light units. I had mine replaced because it kept saying that a bulb was out.
      03-06-2009, 06:59 PM   #7
1N54E92
1N54E92's Avatar
Drives: BSM F30 M-Sport
Cool
I have the same problem. I took it in but the dealer said light wasn't out.Something about high resistance on rear brake light bulb. Next day, code was gone. The code back on and off for few months. Just last week it finally went out and the error code is not going away. I will be taking it in for bulb replacement.
