02-06-2021, 09:04 AM | #1 |
Rep 24
When to change antifreeze? How many liters?
I have a B38 Engine 2015 118i LCI vehicle. The Antifreeze Water level appears below. Should I do a complete replacement? How many liters should I buy? Or is it enough to just add?
02-06-2021, 07:15 PM | #2 |
Rep 1,345
See your manual. It does not look like replacement is ever necessary, just to add should be fine (provided there's no leak to fix). Mind the concentration: BMW coolant takes distilled water to be 50/50 mixed with (see the bottle label ).
02-07-2021, 03:19 AM | #3 | |
Rep 24
I think I can use this product directly. Also without adding water. https://partsfinder.bilsteingroup.co...cle/febi/24196 |
02-07-2021, 04:39 AM | #4 | |
Rep 1,345
It's best to add the same one you have. That's buy from a dealer (if you still have the factory one). At the very least the colour must match. While having the car serviced the last but one time I had just the coolant added (free of charge, so I made no water comment ). The last time I had the car serviced (an official service every time) the mechanic checked the density and made no comments on it. So a little of undiluted is fine but for colder climates only, as it increases frost resistance. Keep in mind that in a warmer climate higher concentration should make it more vulnerable to boiling. Last edited by No one; 02-07-2021 at 04:47 AM.. |
02-07-2021, 05:28 AM | #5 | |
Rep 24
thank u very much for your help |
02-07-2021, 06:10 AM | #7 | |
Rep 24
02-07-2021, 06:30 AM | #8 | |
Rep 1,345
