BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > Welcome home lighting
      07-30-2012, 09:45 AM   #1
LUV2XLR8-NL
LUV2XLR8-NL's Avatar
Netherlands
Drives: BMW 116i Business Sportline
Perhaps very easy, but it I cannot make it work...
The onboard manual is not that very clear as well.
Who of you guys can tell me how to switch on the welcome home lighting function. So, that if you arrive on your destination the lights are on for a fixed period of time.
I have Xenon with light and rain sensor. Switch is on automatic.
Everything will be okay in the end. If it's not okay, it's not the end.
      07-30-2012, 10:44 AM   #2
neoneon
Drives: BMW
Do you mean when you arrive at your destination and turn off the engine, the lights stay on for let us say 3 minutes while you close the car and walk away?
      07-30-2012, 11:09 AM   #3
did75
Drives: 2016 f48 x1 xline (eu spec)
On mine, with Xenon and light sensor as well, when you turn off the ignition, before leaving the car, pull the left (turn indicator + high beam switch) handle, get out, lock the car and light stays on for around 40secs.
      07-30-2012, 11:16 AM   #4
I think the Welcome light feature lights up the car when you unlock it, while the feature LUV2XLR8-NL wants is what BMW calls Follow Me Home or something like that. If the car has it, it should be possible to adjust the delay in a settings menu in the iDrive system.
      07-30-2012, 11:27 AM   #5
ronald89
ronald89's Avatar
Netherlands
Drives: BMW 118d
As far as I know there are 2 types of "coming home" lights:
1. Turn on the switch for your headlights (or set it to automatic - the light symbol with the A above it). When you arrive at your destination, turn off the engine and leave the lights switch on. The lights will stay on as long the car is unlocked. After locking the lights will go off.
2. You can also let the headlights stay on for a certain time. The manual says the following about this: If the headlight flasher is activated after switching off the ignition, the low-beam headlights illuminate and remain for a certain time.
You can set this via: Settings -> Lights -> Home lights
The first one works fine for my old 1 series. The second one I cannot test because it has no iDrive
      07-30-2012, 02:19 PM   #6
MartinHattingh
MartinHattingh's Avatar
South Africa
22
Drives: 2012 X3 XDrive 2.0i
Spot on. You can set the time it remains on for via the menu above. Mine is set at 90 seconds.
Stop, switch off, pull the flasher, and there will be light...
      07-30-2012, 02:46 PM   #7
LUV2XLR8-NL
Netherlands
THNX, the catch for me was completly turn off the car. Was used to stop the engine, music still on, grab my things from the back seat and than lock the car ;-)
      07-08-2019, 12:28 PM   #8
Matty26
Drives: Bmw f20 118i
Has anyone found a way to code the headlights to stay on for a set duration without having to pull on full beam?
