BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > F20 Classifieds > BMW F20 M140i LCI B58 Sound w/ Fi EXHAUST Quad Tip Setup (M-Tek Diffuser)
      10-19-2022, 02:36 AM   #1
FiEXHAUST
FiEXHAUST's Avatar
197
Drives: BMW 1-8, M and X series
BMW F20 M140i LCI B58 Sound w/ Fi EXHAUST Quad Tip (M-Tek Diffuser)
Sound check:
FI EXHAUST F20 M140i LCI Product page: click here
Frequency Intelligent Exhaust offers the ideal attributes for two different situations. It's the perfect exhaust system for those who enjoy cruising in comfort and experience sports car resonance and with Fi EXHAUST all you need to do is just press a button to experience that.
The Fi EXHAUST has been tested to provide the most outstanding performance and superlative sound frequency via an optimum pipe diameter, CAD and unparalleled design, valvetronic technology, high grade materials, and manufacturing progress.
The exhaust is made from a high-grade stainless steel material and skillfully detailed and finished using TIG welding manufacturing high quality and clean welds. Moreover, the time of the installation would not take that long, it is uncomplicated to mod, due to the exhaust system offering a 100% bolt-on fitment.
Fi EXHAUST system is paired with our remote control to adjust the desired sound volume from quiet pleasant to sporty dynamic with a simple press of the button. While closing the valves, the exhaust gasses are transmitted through the muffler, the feeling of the driving experience will come up with a more low-key silent mood. Alternatively, while open the valves for maximum flow and performance it makes a barbaric sports car sound, which highlights Fi EXHAUST frequency and aggressive volume of the sound.
Fi users can choose between our standard remote control system and our new generation Fi Pro Control System, which provides more customization options. The new Fi Pro 2 button design remote control is lightweight, ergonomic, and provides a smooth way to switch between Street and Race sound profiles. The design is intuitive and has a nice grip, and the aluminum alloy ring can be specialized in 14 different colors or changed to forged carbon rings with a distinctive marble-like surface.
Furthermore, just search “Fi EXHAUST Pro”, the users of Fi can download our APP on both Apple Store and Google Play. Within the App, users can set personalization and also monitor real-time valve conditions with the help of our smart and user-friendly interface. According to Auto Mode choice based on RPM/Speed/Turbo Boost, while Auto Mode is switch on the system will intuitively open valved regarding on the auto mode way and set data unit, such as, at 3000 RPM.
The CEL issue could be solved by the Fi Pro Control System after installed the aftersales market exhaust. On an engine, start-up Fi users can turn on the Auto Scan function to scan and delete any CEL connected to the catalytic converter immediately. This effect can be opened on Fi Pro App and is available on chosen car models. Manual debugging can also eliminate the unwanted CEL attached to the catalytic convertor.
BMW F20 M140i LCI features:
  • Full valvetronic exhaust system, which includes front pipe, mid pipe, valvetronic muffler and tips.
  • Tips: Exhaust can be finished with dual or quad tips. The quad tip setup will require M-Tek Diffuser.
  • 2 downpipe options to regulate exhaust gas flow and sound: Ultra high flow catless and Sport 200 cell downpipes.
  • Ceramic Coating can be applied to the downpipe to keep the heat in the exhaust flow and prevent it from radiating to surrounding components.
  • Manufactured from a high-grade T304 stainless steel.
  • Expert TIG welding techniques.
  • Weight reduction compared to OEM/Stock exhaust.
  • Street/Race exhaust sound profiles.
  • Rigorously sound tuned exhaust sound frequency.
  • Horsepower increase and low back pressure.
  • Guaranteed bolt-on fitment using precision crafted design.
  • Exhaust tips available in 5 colors: Silver, titanium blue, diamond black, gold and with carbon fiber.
  • Fi intelligent ECU exhaust control valve flaps can also be controlled with Fi Pro Control System (optional).
  • Available for F20 / F40 M135i / M140i models.
catback, downpipe, exhaust, f20, m140i, muffler, valvetronic
