BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > F20 Right LED Failure
      08-18-2020, 02:24 AM   #1
Mo-T_120D
Mo-T_120D's Avatar
South Africa
Drives: BMW, 120D, 2015
Exclamation F20 Right LED Failure
Hey guys I have a problem with the driver side headlight. My old headlight broke so I replaced it with a used one. Now the new headlight came with everything so I just plugged it in and it's not turning on. I am getting a high beam head-light right Failure and dipped beam right failure error.
I have e-sys 3.2.7 that gives error C157 when I try to code
Thanks in advance
      09-04-2020, 03:18 PM   #2
Regressor
Regressor's Avatar
Drives: F20 & E83
Did you disconnect the battery when replacing? Does the auto leveling motor do its thing when turning on? May have popped a fuse, its in the FEM on the passenger side behind some plastic.
c157, dippedbeamrightfailure, f20, highbeamhead-lightrightfailure
