07-25-2009, 10:33 PM | #1 |
Rep 3,496
BMW Surfers, what do you do with your key?
Going down to cali for vacation all of august, I was wondering, what do you guys do with your car key while you are surfing?
some italian, german, and japanese ones; and on order more of the same
07-26-2009, 12:28 AM | #3 |
meh
123
Rep 1,756
I put the key on a floating keychain (the kind you use for boat keys) and attach that through one of the loops on my trunks. I have done this countless times with no ill effect. The key is fine in the washing machine too FYI.
07-26-2009, 01:00 AM | #4 |
Dictator
55
Rep 1,811
Doesn't your wetsuit have a waterproof pocket(?) Most all wetsuits have them.
Otherwise use a combination style car key safe and hang it off under the car frame, etc.. That's the easiest and best way, imho. (you can stash wallets, credit cards, etc. in there too.) And just wear a Road ID bracelet in case you ram your face into the ocean floor. |
07-26-2009, 01:58 AM | #5 |
Rep 2,431
when I scuba I take my truck and put in my hitch where there is a combination lock
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
07-26-2009, 06:26 PM | #6 |
Rep 260
I pull the key out of the fob, leave the fob in the trunk, lock the car with the key and then put the key in the pocket in my wet suit. The little key pocket in my wet suit (as well as past wet suits) is definitely not water proof.
This works for cars with comfort access as well, because once you pull the key out of the fob the car doesn't detected the key in the car anymore. If you leave the fob with the key in it in the car and try to lock it the car will unlock itself automatically when it detects the key/fob in the car.
07-26-2009, 08:51 PM | #7 | |
Where'd my VTEC go?
481
Rep 6,067
If you have CA and you leave the fob in the trunk and close it, it will re-open the trunk if it does not sense another fob outside. Yes, I have tested it without the metal key in the fob. I have not tested to see if the DOORS will unlock themselves without another fob outside, but that scenario is hard to come by in the real world. Usually you would use the CA ridges on the handle to lock, and the ridges dont work if the fob is not outside of the car with you. Or press the lock button on the fob, which obviously requires the fob to be in your possession.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
07-26-2009, 09:56 PM | #8 | |
Rep 3,251
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
07-26-2009, 10:15 PM | #9 |
Where'd my VTEC go?
481
Rep 6,067
...and why would one do that?
You can have the fob in the cabin and lock it with the metal key and it will stay locked.
07-27-2009, 12:29 AM | #10 |
Rep 3,251
I am talking about cars with CA. Since it is impossible to lock the key inside the car while it is still detectable by the car.
07-27-2009, 12:43 AM | #11 |
Where'd my VTEC go?
481
Rep 6,067
I'm pretty sure it's possible. I just haven't tested it yet.
07-27-2009, 02:17 PM | #13 |
Rep 1,009
Drives: 2007 JB/Saddle E92 335i
You can buy a magnetic box that you stick on your frame under your car and then keep the key to that in your wetsuit. My friend has one that he keeps his spare in just in case he loses his main key.
07-27-2009, 03:27 PM | #14 |
Rep 311
Drives: F31 M Sport
07-27-2009, 04:05 PM | #15 |
Rep 2,575
Drives: '73 2002,'18 X5 35d,'17 328d T
1988 E28 535is Euro Conversion --- sold 2009 E90 335 6MT --- sold 2003 E39 540iT Msport --- sold |
07-28-2009, 12:21 AM | #16 | |
Rep 260
