BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > BMW automatic windows malfunctioning
      05-19-2023, 05:47 PM   #1
raz2121
Drives: BMW 1 series (F20)
I have 2012 f20 5 door and recently my windows have started to automatically come back down after reaching the top, it started with my driver side window only which eventually got completley stuck in a closed position (been like this for over a month now) however, all of my other windows also started to have the same issue I’ve tried all the basic fixes online but none of these have worked, I am planning on going to an electrician & mechanic but I’d rather make sure there’s no way I could fix it myself. If anybody has an idea or solution to this probably I’d appreciate you letting me know.
      05-20-2023, 07:39 AM   #2
IJO
Drives: BMW 116I F20
Have you done the "hold the up button in for a few seconds" reset?
      05-24-2023, 10:04 PM   #3
raz2121
Didn’t really work for me, ended up just taking door trims and bolts off till the window dropped itself then disconnected the negative terminal on the battery for 5 minutes. Once everything was bolted up and fitted again the window was working fine just gotta hope it stays that way now. Appreciate the advice though
      05-25-2023, 03:22 AM   #4
IJO
Sometimes it helps to lubricate the channels the glass slides in. If the motor is overloaded by a stiff mechanism, the power is shut off so the window will just stop.
