BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > DIY Guides and Instructions > BMW Bumper and Bonnet/Hood Alignment
      04-07-2019, 02:01 PM   #1
Dolan-93
Drives: 2014 BMW F20 116i Sport
Hi there,
Hopefully I'm posting this in the correct place (apologies if not)
Looking for a bit of help. I recently changed my headlight units on the car (Bmw F20) and think they look much better.
The issue I'm having is that when I reinstalled my bumper, there is a significant gap on either side, where it connects to the bonnet. I have messed around with the torx screws securing the top of the bumper, as well as the two loop latches that can be twisted on the bonnet, but I am unable to rectify this gap. Hopefully someone out there can help me out with this, many thanks in advance. There are a few pics below to show what I'm talking about
      04-07-2019, 11:15 PM   #2
No one
Drives: F21 118i
They suggest you should mind the alignment when installing the headlights:
      04-08-2019, 10:59 AM   #3
Dolan-93
Thanks for the reply pal! Yeah I figured the headlights were the culprits. Going to loosen the bolts on the lights and mess around with the bumper to try and align it correctly. Many thanks
      06-11-2019, 04:58 PM   #4
gwizzer70
Drives: 116i
headlight bonnet hood alignment
I have the same thing on my 1 series on the near side only, what do you adjust ? headlight unit or bumper?
thanks
      06-12-2019, 03:37 PM   #5
No one
Drives: F21 118i
Headlight unit, of course. Do you even know it must throw the light accurately (to pass the MOT test)?
I had my bumper removed at the service (to access/replace some inner cover that had turned out missing) and it went back without any issues with the headlight units (factory fixed) untouched.
      01-11-2022, 07:53 AM   #6
NathObeaN
NathObeaN's Avatar
Drives: M2 Competition (MY2021)
Digging up an old threat but what areas did you need to adjust on the headlight unit to get it to fit correctly? I have the same issue with my M2 after replacing radiator. Doesn’t matter what bolts I adjust or how I move the headlight unit I cannot get those corners on the bumper to sit straight again.
