BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > F20 LED rear light dimmer
      07-12-2018, 04:15 AM   #1
dismalskin
Romania
Drives: F20 118d
Hello,
I have a F20 non LCI with LED rear light and the one on the right is dimmer.
Now I've searched for solution on repair and say that on the X3 (F25) there are some tutorials in replacing the Valeo board from inside.
I have tried to locate such a thing in my tail light but there are only some wires.
Did anyone had and solved this issue ?
This is the link for the X3
https://www.ledsupply.com/blog/commo...ail-light-fix/
Thanks
      05-13-2019, 07:48 PM   #2
geoffozl
Drives: M135i
F20 LED rear tail light
I have identical model (and colour) M135i with identical tail light issue.
Were you able to resolve this issue yourself?
If so, how was this achieved?
Cheers,
Geoff
      05-14-2019, 01:33 AM   #3
Y20DTH
Y20DTH's Avatar
Drives: F20 116i 2014
Same here. As fas as I know, replacing it is the only solution.
      05-14-2019, 02:10 AM   #4
AlkanNavigator
Warranty Advisor
AlkanNavigator's Avatar
Turkey
Drives: F20 116i Sport Line N13
Hi everyone,
I have 2012 F20 116i Sport Line and same problem.
The rear light system of 1 series is different from X3. When you remove the headlamp in X3, we can access the Valeo chip. However, in our laminates, the system is completely closed and inaccessible. The only way to get to the motherboard is to remove the window from the rear lamp and detach it from the main unit. In this way, the problem is solved if we can directly connect the LED.
But this method may be troublesome. Because the water from the outside and the air will enter the rear lamps.
There seems to be no choice but to change the rear lamp.
By.
BMW | MINI
JAGUAR & LAND ROVER
Warranty Advisor
      05-29-2019, 08:41 AM   #5
krugerjq
South Africa
Drives: X3 2d M Sport, F800GS
Had the same problem with my wife's 118i.... Was just out maintenance plan when we noticed it. Had to replace complete light out of my own pocket. It is a non replaceable LED driver
      10-22-2020, 08:37 PM   #6
M135ier
Austria
Drives: M135i
Yep I'm in the same boat. Same right rear cluster looks to have been replaced under warranty before I bought it ie. my M135i is a July 2013 build and the right rear is currently a 2015 cluster so the original owner had issues with the same cluster. There is no way to access the circuit board from what I could see in the F20's and I confirmed with BMW Service that the only option is replace the whole cluster unfortunately. Was quoted $440aud as the cheapest they could go so bought a Valeo OE 044643 (rear right p/n) off eBay for $290aud
https://www.valeoservice.com/en-com/...A_new_zealande
      11-05-2020, 09:10 AM   #7
raphaelpais
Portugal
Drives: F20 116i
2012 BMW 116i  [0.00]
Had the same problem... got it fixed for 50€.
a led/electrical specialist can open the taillight and repair it... not a simple fix to do at home unfortunately.... (not as easy as the X3 led tail light!)
you have to make your way to the leds melting part of the plastic.. and seal it after the repair.
at least was much cheaper the a oem bmw tail light.
