BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > BMW F20 116i Tuned
      03-26-2016, 10:01 PM   #23
CyberKnight
Turkey
Drives: 2012 F20 116i
Hi,nice car buddy,congrats.What about oil temp. ? Also i have got a 116i urban pack and I want to upgrade it to 205 hp with remap.But i care about engine oil temp.Because you know there is a oil heat exchanger difference between 118i/120i and 116i.Bmw recommends to not exceed 120 C (248 F) oil temp.In Turkey some of remapped 116i (200+ hp) owners are in trouble with oil pump failure.I think we should retrofit our engines with 118i/120i oil heat exchanger or an aux oil cooler.
Any recommendation for oil cooling ? What is the best price/performance solution ? aux cooler or 118i heat exchanger kit ?
      03-27-2016, 08:29 AM   #24
M1fortyeye
Drives: m140
My remapped 2012 116i gets to max 123 degrees when pushing it hard and it goes fast back to 120 even at 4-5k rpm
With coolant its different - it's 110 at normal driving and around 95 at less normal..
      03-27-2016, 08:40 AM   #25
selçukdal
selçukdal's Avatar
Drives: Bmw M4 Maserati GT MC Huracan
thanks bro, i never saw more than 120 mine is always under than 120 i just using motul oil. but after hybrid i dont know what will happen to oil temp so if its too high i will buy an oil cooler it is the best way for cooing oil.
ınteresting i saw between 115-120 at most in track day
      03-28-2016, 03:33 PM   #26
CyberKnight
Turkey
last day i drove kumburgaz to merter as fast as possible in sport mode,engine oil max 123 C (stock f20 116i 136 hp).I think it will be 135+ C after remap.Also summer is coming
      03-29-2016, 03:38 PM   #27
okan992
okan992's Avatar
24
Drives: f30 lci 320i
nice car selçuk congrats..
i also drive a 2015 lci 320i remapped to stg1plus and a itg profilter. My 100-200 is about 16.9 and 0-100 about 6.4. Im considering catless downpipes following week.What is your peak boost calculations? Mine has 1.49bar peak and it ends with 1.10bar. Also i like to know where did you get the gfb dv+ in ankara ? And do you think it makes a difference? And the last question, how much is it?
      03-29-2016, 06:25 PM   #28
selçukdal
selçukdal's Avatar
Thanks a lot, what is slope for 100-200 time? Dp will make great difference, i had hybrid upgrade today so my turbo boost would change a lot but before hybrid peak was 1.37. You can get from boosterperformance in sasmaz for 600 tl. It is usefull
      03-30-2016, 10:05 AM   #29
okan992
okan992's Avatar
24
Slope was -2.2 in 100-200. So, my boost is too high if yours was 1.37. You know we can use mass blocks in vcds for getting logs. VCDS shows 1.45bar peak and 1.10end. But with elm327 and dash command app, peak is 1.49 and ending is 1.112bar. I think elm327 and applications are not accurate. When i decat my car, i will flash the stage 2 software and tune it to 1.55bar, maybe a little timing setting. m135i spark plugs and ignition coils are also in my list for stage 2. Im also curious about the peak boost driving at sea level.
      03-31-2016, 02:18 AM   #30
selçukdal
selçukdal's Avatar
Good time congrats. Yes mine was 1.37, i didnt use both vcds and elm327 the most accurate one is in photo. Ignitions must replace with better ones, im sure we would have more boost and power at sea level
      03-31-2016, 02:23 AM   #31
selçukdal
selçukdal's Avatar
For logs
      03-31-2016, 04:27 AM   #32
Slyly
Drives: F20 1.16
Beru spark plug has broken down on my Stage 2. It crashed to cylinder. Had half of my engine rebuilt.
Than used Denso. Failed at some point. Now using NGK. Pulling great so far.
Beru was 80 something TL each.
Denso was 360 for 4.
NGK is 100 for 4.
Before spark plug failure i was over 260km/h
Now have a 10bhp reduced Stage 2. Catless DP
Denso did not break the engine. It was skipping ignition at a certain RPM (somewhere around 4.5k) which made the car jump.
      03-31-2016, 11:20 AM   #33
selçukdal
selçukdal's Avatar
Im sorry for your car im using m135's spark plugs and im happy with them
      03-31-2016, 12:02 PM   #34
okan992
okan992's Avatar
24
NGK is 100 for 4.
So sorry for your car bro. Is that about the timing and the octane? Are you using alcohol with 95 or is it only 95? If this was about the timing and octane, then we should use a boost controller like profec. When we sense any timing problem, should reduce the boost. with a boost controller it is so easy. Ofcourse, when we running with alcohol, we could maximize the boost.
      03-31-2016, 12:16 PM   #35
Slyly
Drives: F20 1.16
I am running 95 Nitro now. Used to run regular 95 before.
How much are M1.35 plugs? I am really happy with 100 TL for 4. And they are great performance.
Also i am running Mobil1 Formula ESP instead of Castrol.
And yes. It was due to octaine and spark plug.
The plugs could not stand to the pressure.
Still an awesome machine. Made it to Abant with 4 people with luggage over 260 km/h with only 2 working cylinders (reduced the speed after notices the shake on engine. Did not even give any warning the whole trip. It was 3 cylinder, but than shut down another one due to mega-shake. Saw the whole story at diagnose afterwards).
      12-04-2016, 03:47 PM   #36
BeWide
Clean, Low and Wide, that is the style !
BeWide's Avatar
Belgium
Drives: 318D E90
Hello here,
sorry to dig this topic, but some advice would be awesome !
I plan to do some upgrade on a 116i .
I'm plan to do :
- K&N filter
- Spark plugs
- Intercooler
- Complete exhaust catback
- GFB DV+
But in regards of your experience, I would like to have your ideas.
- Which intercooler would be better , 135i OEM or aftermarket model (bigger) something like this : here
- I've read that you've got really big problems with sparks plugs, what would be recommended ? 135i oem ?
- In term of perfs, do a down cat is really recommended? what about the
Sound comfort?
- Do an oil exchanger need to be mounted ?
Thanks fir your advice's guy's !
      09-11-2017, 03:56 AM   #37
BMW 116i Urban
Drives: BMW116I f20
Hi, please tell me if you have any problem with the oil temperature after tuning, mine has now 195 hp and its stock and i don't know at what temperature should i go slow to cool down.
I know the 116I does not have a heat exchanger like 118I.
Thank you
      09-11-2017, 09:07 AM   #38
BMW 116i Urban
Drives: BMW116I f20
Hello,
regarding the brakes, did you did any upgrade? i found one set from 330d to do a retrofit, do you know if is possible to do?
      11-07-2017, 10:57 PM   #39
selçukdal
selçukdal's Avatar
Thank you
I didn't have any problem with oil. Sorry for late response, sold my car and drive M6 now. So not looking this forum too often.
      11-07-2017, 10:58 PM   #40
selçukdal
selçukdal's Avatar
Hello,
I only changed brake fluid with castrol srf racing. No idea sorry.
      11-24-2017, 12:54 PM   #41
Acceleration TV
Acceleration TV's Avatar
Drives: BMW
Post
I have made a acceleration/ top speed (0 to 250 km/h) video with the temperature display on a tuned 116i (100% stock) with 219hp. Temperature is fine, except when driving at top speed (240 km/h +) for longer than a minute (temp starts to rise to above 130 Celsius).
Video:
https://www.youtube.com/watch?v=0mSwV24cuB8
      12-04-2017, 01:37 PM   #42
Sidewinder1970
Sidewinder1970's Avatar
Netherlands
14
Drives: BMW f20 116i
2012 BMW F20  [10.00]
Video:
Wow, nice work and great inside of the oil temp. Mine f20 also visit BR Performance in the Netherlands. Hope to perform just like you do.
      12-19-2017, 02:14 AM   #43
M1fortyeye
Drives: m140
Video:
I guess you made this video when there was 3.5 degrees outside?
      12-19-2017, 09:05 AM   #44
REd116
Drives: F20 116i
Nice video man..but what was the outside temp?
